9 years, 7 months ago.
mbed OS 5 HTTP Client example fails to build using online compiler.
I'm using the online compiler. The HTTP Client example program under the mbed OS 5 API Documentation fails to build. This is a little bit surprising since I would have expected the published example to have been tested. Or, maybe it is something I'm doing incorrectly. I've built examples similar to this under the mbed Classic OS without issues. The URL to the example is:
The following shows the build errors that occur when trying to build the example. Does anyone have any ideas what is going on here? Is anyone else able to build this example?
David,
Thanks for the message and pointing out the issue.
When i have more information about this i'll get back to you.
All the best,
Andrea, team mbed
posted by Andrea Corrado 18 Aug 2016Hi Andrea, do you have some update?
posted by Felícito Manzano 20 Dec 2016
