9 years, 8 months ago.
Viewing SD card data directly in PC
Hello everyone,
I am using LPC1768 and a SD Card breakout board from Sparkfun (SparkFun microSD Transflash Breakout). I wanted to know if it is possible to read the data stored in the memory card directly in your pc without disconnecting it out from the LPC1768 board. If this is possible what kind of extra circuit do i need to have in between the Pc and the SD card?
My SD card will be inside a device which will take more than an hour to deassemble. So when I need to check the data I just want to connect it to the sd card via a connector and directly view it in the PC, is something like this possible?
any help/suggestion is appreciated.
The lpc1768 can act as a USB mass storage device. You can use the SD card as its memory. See here for some examples
