9 years, 7 months ago.
gpio_read(&gpio) in DigitalOut.h; int gpio_read (gpio_t *obj) in gpio_api.h
Hi all,
I have got a question about the GPIO read function, I can only find out the funtion prototypes in header files: DigitalOut.h, and gpio_api.h respectively.
Does anyone know where do find out the gpio_read() itself? For example, I can write gpio_read (PA_5) to read the status of the GPIO pin PA_5 on the MCU?
Cheers, Daniel L
Hi Daniel,
Hopefully i can help you out here. If you look at the API for digital out, you can then see at line 82 the required call to object:
Import librarymbed
No documentation found.
I hope this helps.
Andrea, team mbed
