9 years, 7 months ago.
cannot compile helloyotta for mbed-gcc
Trying to build "helloyotta" sample for mbed-gcc, but encounter the errors described below:
Ubuntu 12.04.5. Installed latest gcc-arm-none-eabi manually.
Downloaded helloyotta. yotta target mbed-gcc yotta build
info: generate for target: mbed-gcc 1.2.2 at /ade/borisst/helloyotta/yotta_targets/mbed-gcc
The C compiler identification is GNU 5.4.1
The CXX compiler identification is GNU 5.4.1
Check for working C compiler: /usr/bin/arm-none-eabi-gcc
Check for working C compiler: /usr/bin/arm-none-eabi-gcc broken
CMake Error at /usr/share/cmake-3.6/Modules/CMakeTestCCompiler.cmake:61 (message):
The C compiler "/usr/bin/arm-none-eabi-gcc" is not able to compile a simple
test program.
It fails with the following output:
Change Dir: /ade/borisst/helloyotta/build/mbed-gcc/CMakeFiles/CMakeTmp
Run Build Command:"/usr/bin/ninja" "cmTC_4bad7"
[1/2] Building C object CMakeFiles/cmTC_4bad7.dir/testCCompiler.c.o
[2/2] Linking C executable cmTC_4bad7
FAILED: : && /usr/bin/arm-none-eabi-gcc -fno-exceptions -fno-unwind-tables
-Wl,gc-sections -Wl,sort-common -Wl,sort-section=alignment
-Wl,-wrap,main -Wl,-u,_printf_float -Wl,-Map,cmTC_4bad7.map
-Wl,start-group CMakeFiles/cmTC_4bad7.dir/testCCompiler.c.o -lm -lc -lgcc
-lm -lc -lgcc -Wl,end-group specs=nano.specs -o cmTC_4bad7 && :
/usr/bin/../lib/gcc/arm-none-eabi/5.4.1/../../../../arm-none-eabi/lib/libc_nano.a(lib_a-exit.o): In function `exit':
exit.c:(.text.exit+0x34): undefined reference to `_exit'
/usr/bin/../lib/gcc/arm-none-eabi/5.4.1/../../../../arm-none-eabi/lib/crt0.o: In function `_start':
(.text+0xec): undefined reference to `wrap_main'
/usr/bin/../lib/gcc/arm-none-eabi/5.4.1/../../../../arm-none-eabi/lib/libc_nano.a(lib_a-sbrkr.o): In function `_sbrk_r':
sbrkr.c:(.text._sbrk_r+0x18): undefined reference to `_sbrk'
collect2: error: ld returned 1 exit status
ninja: build stopped: subcommand failed.
CMake will not be able to correctly generate this project. Call Stack (most recent call first): CMakeLists.txt:71 (project)
Configuring incomplete, errors occurred!
See also "/ade/borisst/helloyotta/build/mbed-gcc/CMakeFiles/CMakeOutput.log".
See also "/ade/borisst/helloyotta/build/mbed-gcc/CMakeFiles/CMakeError.log".
error: command ['cmake', '-D', 'CMAKE_BUILD_TYPE=RelWithDebInfo', '-G', 'Ninja', '.'] failed
Hello Boris,
I'm not sure that the latest version of GCC is supported by mbed at the moment. As stated in the yotta documentation (it is not in the right section): mbed is tested with GCC 4.9 (see here: http://yottadocs.mbed.com/#windows-cross-compile).
You should also get GCC from this PPA: https://launchpad.net/gcc-arm-embedded.
