9 years, 7 months ago.
Exporting the mbed file to keil ide does not run or debug
I am unable to run the exported source code from mbed. I get error when i run or debug the code. I am using STM32l0 Series controller and would like to program Nucleo board. As i am interfacing and SD card to create a directory and read and write values in to it. As the code was not working i thought of debugging to know the problem. I am using keil ver.5 ide and started running but it did not work. I would like to post the images of those errors that are being raised. /media/uploads/mgvdatalogger/1.jpg /media/uploads/mgvdatalogger/1.jpg /media/uploads/mgvdatalogger/main.c
Mohan,
Can outline exactly what problem you are having. What is your target platform and exporting program?
Regards
-Andrea, Team mbed
posted by Andrea Corrado 12 Aug 2016
This is my problem uanble to run the exported mbed code donot know wats the reason may be i am expecting to be a linker error.
posted by Mohan gandhi Vinnakota 12 Aug 2016
Mohan,
Have you correctly set up the target debug in keil.
http://www.keil.com/support/man/docs/ulink2/ulink2_su_debugdrivercfg.htm
Let me know how get on :)
-Andrea, team mbed
