10 years, 11 months ago.
Serial Communication Output Graph
So I have been trying to implement your serial communication example on my own mbed and computer. For the inputs to the AnalogIn pins I am using a function generator generating a simple 5Hz sine wave. However, the output of the graph in MATLAB doesn't look anything like what I expect and is very noisy. Is there anything wrong with what I'm trying to do with your program? What kind of output did you get from it? Could you maybe post some example outputs the way you did with the range finder example?
