9 years, 2 months ago.
Why Nucleo-F072B I2C no any response and out when use the compiler example program?
Maybe this is the story about ST's I2C...........................
What program are you running on the board? Just basic I2C? Which pins are you using?
posted by Jan Jongboom 10 Aug 2016
  1. include "mbed.h"
  1. define LM75_REG_TEMP (0x00) Temperature Register
  2. define LM75_REG_CONF (0x01) Configuration Register
  3. define LM75_ADDR (0x28) LM75 address
I2C i2c(I2C_SDA, I2C_SCL);
DigitalOut myled(LED1);
volatile char TempCelsiusDisplay[] = "+abc.d C";
char data_write[2]; char data_read[2];
/* Configure the Temperature sensor device STLM75: - Thermostat mode Interrupt - Fault tolerance: 0
  • / data_write[0] = LM75_REG_CONF; data_write[1] = 0x02; int status = i2c.write(LM75_ADDR, data_write, 2, 0); if (status != 0) { Error while (1) { myled = !myled; wait(0.2); } }
while (1) {
i2c.read(LM75_ADDR, data_read, 4, 0);
Calculate temperature value in Celcius int tempval = (int)((int)data_read[0] << 8) | data_read[1]; tempval >>= 7; if (tempval <= 256) { TempCelsiusDisplay[0] = '+'; } else { TempCelsiusDisplay[0] = '-'; tempval = 512 - tempval; }
Decimal part (0.5°C precision) if (tempval & 0x01) { TempCelsiusDisplay[5] = 0x05 + 0x30; } else { TempCelsiusDisplay[5] = 0x00 + 0x30; }
Integer part tempval >>= 1; TempCelsiusDisplay[1] = (tempval / 100) + 0x30; TempCelsiusDisplay[2] = ((tempval % 100) / 10) + 0x30; TempCelsiusDisplay[3] = ((tempval % 100) % 10) + 0x30;
Display result pc.printf("temp = %s\n", TempCelsiusDisplay); myled = !myled; wait(1.0); }
posted by Jason Wang 10 Aug 2016
The program generate by mbed. And the pin is D14/D15
