9 years, 8 months ago.
DCMI on DISCO-F746NG and BSP_CAMERA stalls (OV9655, STM32F4DIS-CAM)
Has anyone got this camera working on the DISCO-F746NG? I'm struggling with the DISCO-F746NG and STM32F4DIS-CAM. The driver suggests it's a straightforward matter of Initialise and Start, but that isn't the end of the story by any means. If you do that it doesn't return from BSP_CAMERA_Init.
It looks like it is getting stuck in a DCMI interrupt. I say this because if I add the line return CAMERA_NOT_SUPPORTED; after the HAL_DCMI_Init(phdcmi); line (in stm32746g_discovery_camera.c) I see the first few characters of the next line of console output.
Removing the added return CAMERA_NOT_SUPPORTED; line and putting CAMERA_Suspend(); in its place allows the BSP_CAMERA_Init function to return and the code to run through until the BSP_CAMERA_Resume() function call.
I have added some interrupt code to main.cpp but that doesn't help. Any ideas?
Here is my full code (except the changes mentioned above to stm32746g_discovery_camera.c):
#include "SDRAM_DISCO_F746NG.h"
#include "stm32746g_discovery_camera.h"
//#include "stm32746g_discovery.h"
Serial pc(USBTX, USBRX);
//SDRAM_DISCO_F746NG sdram;
void DCMI_IRQHandler(void) {
BSP_CAMERA_IRQHandler();
void DMA2_Stream1_IRQHandler(void) {
BSP_CAMERA_DMA_IRQHandler();
pc.baud(115200);
pc.printf("START\r\n");
wait_ms(1000);
#define CAMERA_FRAME_BUFFER 0xC0260000
#define LCD_FRAME_BUFFER 0xC0130000
#define resolution RESOLUTION_R320x240
pc.printf("HAL_Init()\r\n");
HAL_Init();
pc.printf("BSP_CAMERA_Init(resolution);\r\n");
if( BSP_CAMERA_Init(resolution) == CAMERA_OK ) {
pc.printf("OK\r\n");
} else {
pc.printf("Err\r\n");
pc.printf("BSP_CAMERA_ContinuousStart((uint8_t *)CAMERA_FRAME_BUFFER);\r\n");
wait_ms(100);
//BSP_CAMERA_SnapshotStart((uint8_t *)CAMERA_FRAME_BUFFER);
pc.printf("Camera running\r\n");
HAL_Delay(1000);
pc.printf("BSP_CAMERA_Resume();\r\n");
wait_ms(100);
HAL_Delay(1000);
pc.printf("BSP_CAMERA_Suspend();\r\n");
wait_ms(100);
pc.printf("BSP_CAMERA_Suspend-ed\r\n");
while(1);
8 years ago.
My program is getting stuck after BSP_CAMERA_ContinuousStart((uint8_t *)CAMERA_FRAME_BUFFER);
Did you run into this issue or change any other files not mentioned?
The key here was that the Interrupt Handlers should have had extern "C" linkage as the library file is a *.c whereas the handlers are in main.cpp. So adding extern "C" { before void DCMI_IRQHandler(void) and a } after the DMA2_Stream1_IRQHandler function in main.cpp fixed it. No need for changes to any of the library files(e.g. stm32746g_discovery_camera.c)
posted by Chris P 09 Aug 2016
