9 years, 8 months ago.
Compiler error __aebi_assert
Hello If I compile the following program https://developer.mbed.org/users/cam/code/Modbus/ in Nucle-F103RB or Nucleo-F401RE get the following errors: /media/uploads/bcontrol/erro_nucleo-f103rb.png /media/uploads/bcontrol/erro_nucleo-f401re.png
What's the problem?
However compiling with Nucleo-F746GZ get success!
have you checked if F746 is pulling the correct header file ? I would suspect it does, and other targets do not. I could not see in the mbutils.cpp file a proper header inclusion to pull in assert.
Thank you for your quick response, I do not see the error because the files are the same, it is a mystery!
posted by Ivan Gomes 08 Aug 2016
