9 years, 8 months ago.
NUCLEO-F746ZG InterruptIn problem
During my attempts to debug the following test code, (The interrupt for the button will not fire after adding the next interrupts whether set or not)
DigitalOut led1(LED1);
DigitalOut led2(LED2);
DigitalOut led3(LED3);
InterruptIn quadButton(PB_9);
InterruptIn quadA(PC_9);
InterruptIn quadB(PC_8);
void int1() {
led1 =! led1;
void int2() {
led2 =! led2;
void int3() {
led3 =! led3;
quadButton.rise(&int1);
quadButton.mode(PullUp);
quadA.rise(&int2);
quadA.mode(PullUp);
quadB.rise(&int3);
quadB.mode(PullUp);
while(true) {
I've been reading the initialisation code that is executed as part of the InteruptIn constructor, and during TARGET_STM32F7/gpio_irq_api.c the irqs are assigned ect, but what I can't understand is how 2 pins on different ports with the same number can be used together.
using pins PB_9 and PC_9, in gpio_irq_init() the switch statement is executed using 9 (returned from STM_PIN(pin)) so both pins are assigned to irq5, then the irq_index (5) is used to select a channel, so the pins are assigned the same channel, the channel index is selected using a lookup table returning 4 for both, then the data is stored into that index, for both, overwriting the previous data. This doesn't make much sense so I assume I've missed something.
Anyway this is a very long winded way of asking any idea whats going on with the interrupts?
it appears to be a hardware limitation, each interrupt line can only support 1 port at a time
posted by Chris Pepper 05 Aug 2016
