9 years, 7 months ago.  This question has been closed. Reason: Unclear question
V2 Dynamic configuration and an issue you helped with last year
Mike,
I've had my cabinet working since late last year with the pinscape controller at its core. You were great help solving an issue with vendor ID's I was having. (https://developer.mbed.org/questions/60695/Is-there-a-potential-compatibility-with-/).
I'd like to check out V2 but want to avoid the issues with my LEDWiz that occurred before. Is the Vendor ID something that is configurable dynamically in the new version or does it still require a re-compile?
Thanks for building this tool!
Sincerely,
Cary
edit:
I meant to offer the following as well. I am working on a TAOS TSL 1410R CCD linear array sensor mounting bracket that serves a similar function to Lemming77's slide potentiometer bracket. I've FDM printed the prototype and once I verify that it works, I would like to offer the sketchup file to add to your page for download (if you are interested).
Best Regards,
Cary
