9 years, 6 months ago. This question has been closed. Reason: Unclear question
Need Help with linker file for ARM GCC for target Tiva C
I don't have experience with writing linker files for ARM GCC Compiler, I need help to understand how to make one for #mbed for my target.
here's the one which I use, which I believe it doesn't function the way it should be for mbed-OS
* Memory definition:
* FLASH: start point 0x00, lenght 0x40000.
* SRAM: start point 0x20000000 length 0x8000.
MEMORY
FLASH (rx) : ORIGIN = 0x00000000, LENGTH = 0x00040000
RAM (rwx) : ORIGIN = 0x20000000, LENGTH = 0x00008000
* Sections definitions:
* .text - machine instructions.
* .data - initialized data defined in the program.
* .bss - un-initialized global and static variables (to be initialized to 0 before starting main).
* .stack - just contains the pointer to the stack end at the right place.
SECTIONS
/* This section it's the code, containing the NVIC Vector table that must start at 0x0
* Look at the LM4F120H5QR datasheet for details. (Table 2-8. Exception Types)
.text :
_text = .; /* This is an index to the beginning of .text segment. */
KEEP(*(.nvic_table)) /* I should keep the NVIC ISR Table because it's needed by the processor to start. */
*(.text.*) /* This contains the code after the ISR table. */
*(.rodata.*) /* Read only data. */
_etext = .; /* This is an index to the end of .text segment. */
}>FLASH
* .data segment must be placed in RAM but it's originally stored in FLASH
* So I set the data segment in ram, but I specify the load address with the AT
* keyword to set that right after the .text section.
* (Look at the LD documentation. (Optional Section Attributes))
* Thanks https://github.com/utzig for the hints!
.data :
_data = .; /* An index to the beginning of .data segment. */
*(.data.*) /* I should put there all my initialized data of my program. */
*(vtable) /* vtable it's generated by stellarisware to store the NVIC table in ram*/
_edata = .; /* And another index to the end of .data segment. */
}>RAM AT >FLASH
__exidx_start = .;
.ARM.exidx :
*(.ARM.exidx* .gnu.linkonce.armexidx.*)
} > FLASH
__exidx_end = .;
* .bss contains the unitialized variables and must be set as 0x0 during runtime.
* It should be loaded in RAM and particula care should be taken initializing them in the startup file.
.bss :
_bss = .; /* This is an index to the beginning of .bss segment. */
*(.bss.*) /* The un-initialized data should go there. */
*(COMMON) /* All the other stuff should be put there */
_ebss = .; /* End index for .bss segment */
}>RAM
And I would really appreciate it if someone provide me useful tutorial about this topic
