9 years, 8 months ago.
Problem with cmsis_nvic.c
I hope someone answer me this time, I asked before about "if I could enabling systick for OS as OS-clock" because the problem was that software jumps to "Hard Fault Handler" . So I tried to enable General Purpose timer instead, The problem still persist. So I followed the code by debugger and here's what I found:
(I am porting mbed to Tiva C TM4C123 launchpad, my compiler is GCC, I am using CDT for building, And GDB openOCD for debugging, and integrated all those tools on Eclipse)
it jumps to hard fault handler handler at line
vectors[i] = old_vectors[i];
here's code which I use
#include "cmsis_nvic.h"
#define NVIC_RAM_VECTOR_ADDRESS (0x02000000) // Vectors positioned at start of RAM
#define NVIC_FLASH_VECTOR_ADDRESS (0x0) // Initial vector position in flash
void NVIC_SetVector(IRQn_Type IRQn, uint32_t vector) {
uint32_t *vectors = (uint32_t*)SCB->VTOR;
uint32_t i;
// Copy and switch to dynamic vectors if the first time called
if (SCB->VTOR == NVIC_FLASH_VECTOR_ADDRESS) {
uint32_t *old_vectors = vectors;
vectors = (uint32_t*)NVIC_RAM_VECTOR_ADDRESS;
for (i=0; i<NVIC_NUM_VECTORS; i++) {
SCB->VTOR = (uint32_t)NVIC_RAM_VECTOR_ADDRESS;
vectors[IRQn + 16] = vector;
uint32_t NVIC_GetVector(IRQn_Type IRQn) {
return vectors[IRQn + 16];
I have configures cmsis_nvic.h to
#define NVIC_NUM_VECTORS (10 + 66) // CORE + MCU Peripherals #define NVIC_USER_IRQ_OFFSET 16
Can anyone please let me know what is going wrong here? or at least where should I debug or read ???
In general: Either step through it with a debugger, or otherwise disable stuff until it does not crash anymore.
Specifically here, from the reference manual I get:
Quote:
The internal SRAM of the TM4C123GH6PM device is located at address 0x2000.0000 of the device memory map.
That is not what you have set the start of your SRAM to.
