10 years, 11 months ago.
How to convert String to Float value
I want to send a string over serial to my mBed. Once i receive this string or array of characters, how can I convert the numbers given to a float value?
I have an array of char[9] = {1,2,3,4,5,.,4,3,2} or a string "12345.432", how do I convert this to a float = 12345.432??
Thank you for all the help
Use the function atof() which is part of stdlib.h (or cstdlib).
You can use it like that
Using atof
#include <cstdlib>
void main()
float cnv;
cnv = atof("3.1415");
while(1)
Hi, You can use a scanf function or do the maths iterating over the char array. For this conversion you should probably use double instead of float (however give it a try with floats you should quickly see the issue).
double iPart = 0.0, dPart = 0.0, f = 0.0, mult = 0.1;
const char *buff = "12345.432";
sscanf(buff,"%f",&f);
printf("%f\n",f);
f= 0.0;
char *p = (char*) buff;
while(*p != '.') {
iPart = iPart*10 + ((*(p++)-'0'));
p++;
while(*p!= '\0') {
dPart += ((*(p++)-'0'))*mult;
mult *= 0.1;
f = iPart + dPart;
printf("%f\n",f);
The scanf is big function able to handle lost of conversion etc etc.. for a simple conversion and with low memory using the second option is probably the best. Hope this helps Have a nice day. Clément
