13 years ago.
Problem excercise 4.1 (ethernet) book ARM MICROCONTROLLERS2 BERT VAN DAM
Hello, This is a book that uses the mbed microcontroller. I succeeded the other examples in this book without a problem. This is a chapter about Ethernet. The example code (whitch i copy paste from the website, so no typemistakes) gives a lot of erros anybody already succesfully made this example?? thnx in advance
#include "EthernetNetIf.h"
#include "HTTPServer.h"
EthernetNetIf eth;
HTTPServer svr;
DigitalOut led1(LED1, "led1");
EthernetErr ethErr;
int count = 0;
do {
printf("Setting up %d...\n\r", ++count);
ethErr = eth.setup();
if (ethErr) printf("Timeout\n\r", ethErr);
} while (ethErr != ETH_OK);
printf("Connected OK\n\r");
const char* hwAddr = eth.getHwAddr();
IpAddr ethIp = eth.getIp();
printf("IP address : %d.%d.%d.%d\n\r", ethIp[0], ethIp[1], ethIp[2], ethIp[3]);
svr.addHandler<SimpleHandler>("/hello");
svr.bind(80);
printf("Server listening\n\r");
Timer tm;
tm.start();
while (true) {
Net::poll();
if (tm.read() > 0.5) {
led1 = !led1;
tm.start();
"no instance of constructor "mbed::DigitalOut::DigitalOut" matches the argument list" in file "InetTest//main.cpp", Line: 8, Col: 29
"identifier "PinDirection" is undefined" in file "mbed.bld//gpio_api.h", Line: 32, Col: 41
"identifier "PIN_INPUT" is undefined" in file "mbed.bld//DigitalIn.h", Line: 55, Col: 30
"class "mbed::Base" has no member "add_rpc_class"" in file "InetTest/RPCInterface//SerialRPCInterface.cpp", Line: 42, Col: 10
"type name is not allowed" in file "InetTest/RPCInterface//SerialRPCInterface.cpp", Line: 42, Col: 24
"expected an expression" in file "InetTest/RPCInterface//SerialRPCInterface.cpp", Line: 42, Col: 34
in total 45 of this errors, but they all look like the 6 i posted
thnx again
13 years ago.
Hi, Adrian, first the EthernetNetIf and HTTPServer libraries are deprecated.
Second why dont you try this HTTPServer Example for this page (is the same exercise you post, but is working and dont have errors), but remenber that this exercise use deprecated libraries
http://mbed.org/cookbook/HTTP-Server
Greetings
P.D. The new EthernetInterface doc is here: http://mbed.org/handbook/Ethernet-Interface
Hello, why is this library deprecated? On google i find that this means that you should avoid to use this?
posted by 04 May 2013Hi, Adrian, deprecated means that the library maybe in any moment can dissapear or that the support for the library will end. If you look in wikipedia http://en.wikipedia.org/wiki/Deprecation in the part of "Reasons for deprecation" you will find for what i do my recomendation
Greetings
posted by 04 May 2013Hi Ney, Ok thnx i see, so i will work with the new library instead, but i got some new problems there, i posted a new question about the problem i have with the example program TCP socket Hello world which i found on the new ethernetinterface.doc. if your familiar with this could you have a look please? Thnx in advance Greetings
