10 years, 11 months ago.
Problem with MCP3551 and PT100
HI I have a problem with read ADC from MCP3551. MCP is using SPI. I want to use MCP3551 and pt100 to read temperature.
I can't read right values from MCP3551.
Devices is good, because I checked in Atmel Studio
This is my C -code.
unsigned char dd_zmien_kolejnosc_bitow(char a);
uint8_t LsbMsb( uint8_t data);
uint8_t REVERSE_BITS(uint8_t a);
SPI spi(NC, D12, D13); // mosi(out), miso(in), sclk(clock)
DigitalOut cs(D8); // cs (the chip select signal)
Timer timer;
Serial pc(USBTX, USBRX); // tx, rx ( the usb serial communication )
uint8_t aByte[4],rByte[4],oByte[4];
bool OVH, OVL, rOVH, rOVL;
unsigned long ends=0,delta=0;
uint32_t adc,radc;
timer.start();
spi.format(8,0);
spi.frequency(5000000);
pc.baud(19200);
cs = 1;
wait_ms(300);
// lets just do this forever
while (1) {
delta = timer.read_ms()-ends;
if(delta > 75)
cs = 0;
wait_us(737400);
aByte[3] = spi.write(0xFF);
aByte[2] = spi.write(0xFF);
aByte[1] = spi.write(0xFF);
aByte[0] = spi.write(0xFF);
cs = 1;
pc.printf("senByte3=== %u ", aByte[3]);
pc.printf("senByte2=== %u ", aByte[2]);
pc.printf("senByte1=== %u ", aByte[1]);
pc.printf("senByte0=== %u\n", aByte[0]);
rByte[3]=REVERSE_BITS(aByte[3]);
rByte[2]=REVERSE_BITS(aByte[2]);
rByte[1]=REVERSE_BITS(aByte[1]);
rByte[0]=REVERSE_BITS(aByte[0]);
pc.printf("senByte3r=== %u ", rByte[3]);
pc.printf("senByte2r=== %u ", rByte[2]);
pc.printf("senByte1r=== %u ", rByte[1]);
pc.printf("senByte0r=== %u\n ", rByte[0]);
radc=(aByte[2]<<16) + (aByte[1]<<8) + aByte[0];
pc.printf("przedkonwerscji %d\n", radc);
rOVL = ((aByte[2] & 0b10000000));
rOVH = ((aByte[2] & 0b01000000));
if(rOVH==1){ pc.printf("ovh=1\n");};
if(rOVL==1){ pc.printf("ovl =1\n");};
//will not touch the outgoing code. Leaves the last valid.
if (rOVH && !rOVL)
aByte[2] &= 0b00111111; // clear both flags from byte when positive
if ((!rOVH && (aByte[2] & 0b00100000)) || rOVL ) //when OVH is not set and signed (21th) bit is set we have negative value
aByte[2] |= 0b11000000; //set remaining bits high
aByte[3] =0xFF; //sets high order byte, value is then negative.
float calRAdevice1 = 13607; //stores the series resistor value
//resistor of RTD
const int RZero = 100; //resistance at 0°C
pc.printf("po konwerscji %d\n", radc);
float rRTD = calRAdevice1 * (radc / ( 2097152 - radc));
// pc.printf("kontrol 2 %f\n", rRTD);
rRTD = (rRTD / RZero) - 1;
// pc.printf("kontrol 3 %f\n", rRTD);
float rtemperature = (rRTD * (255.8723 + rRTD * (9.6 + rRTD * 0.878)));
char buffer[10];
sprintf (buffer, "%4.0f", rtemperature);
pc.printf("temperatura %d\n", buffer);
pc.printf("////////////////////////////////////////////////////////////////////////////////////////\n");
// wait_ms(74);
// wait_ms(1);
//ends = timer.read_us();
else
ends = timer.read_ms();
cs =1;
bool MCP3551_ready(void)
{ DigitalIn miso(D12);
//int ALA= (D12);
int end;
if((timer.read_ms() - end)> 74)
cs = 0;
wait_us(1);
if(miso == 0)
return 1;
else {
end = timer.read_ms();
cs =1;
return 0;
else return 0;
{ static const uint8_t reverse_lookup[] = { 0, 8, 4, 12, 2, 10, 6, 14,1, 9, 5, 13,3, 11, 7, 15 };
//int a;
a= ((reverse_lookup[(a & 0x0F)]) << 4) + reverse_lookup[((a & 0xF0) >> 4)];
return a;
uint8_t i,bit,buffer=0;
for(i=0;i<8;i++)
bit = data & (1 << i);
buffer = (buffer << 1) | bit;
return( buffer );
//Funkcja zamiany kolejności bitów LSB <-> MSB
int i, c=0;
for(i=0; i<8; i++)
if(a&(1<<i))
c |= (1<<7-i);
return c;
Could you help me find a mistakes or might by somebody have good code to read MCP3551.
