10 years, 10 months ago.
Possibly buggy firmware for LPCXpresso 1549 and 11U68
Where is the source code for lpc4322 firmware for those 2 boards? http://developer.mbed.org/teams/NXP/wiki/Updating-LPCXpresso-firmware
I suspect a bug in USB Serial part in the firmware. When I send back what I receive on those 2 boards, the last char either is not sent back or something else is sent back. I tried with another USB Serial on a different port and it was working OK. The problem starts when 3 or more bytes are sent, afterwards if I send 1 byte, I do not get back anything.
Sample application for LPC1159 (I used mbed-src library because I was debugging)
Serial pc1(USBTX, USBRX);
Serial pc2(P0_9, P0_29);
Serial pc3(P0_0, P1_3);
pc1.baud(115200);
pc1.printf("\r\nPC1: Serial Echo Server - 115200\r\n");
pc2.baud(115200);
pc2.printf("\r\nPC2: Serial Echo Server - 115200\r\n");
pc3.baud(115200);
pc3.printf("\r\nPC3: Serial Echo Server - 115200\r\n");
while(1)
if (pc1.readable())
pc1.putc(pc1.getc());
if (pc2.readable())
pc2.putc(pc2.getc());
if (pc3.readable())
pc3.putc(pc3.getc());
Output on port 1
<<< \x0D\x0APC1: Serial Echo Server - 115200\x0D\x0A >>> 1 <<< 1 >>> 12 <<< 12 >>> 123 <<< 12? >>> 1 >>> 12 <<< 12
Output on port 2
<<< \x0D\x0APC2: Serial Echo Server - 115200\x0D\x0A >>> 1 <<< 1 >>> 12 <<< 12 >>> 123 <<< 123 >>> 1 <<< 1 >>> 12 <<< 12
Output on port 3
\x0D\x0APC3: Serial Echo Server - 115200\x0D\x0A >>> 1 <<< 1 >>> 12 <<< 12 >>> 123 <<< 123 >>> 1 <<< 1 >>> 12 <<< 12
I hope this demonstrates the issue.
Cheers, Jurgis
Most likely it is buffer overflow. 3 bytes per port buffer seems too small. Did you try one port first and slowly increase the number of bytes sent?
posted by HM Yoong 14 Apr 2015Yes, I tried lots of things during 2 days when I tried to find the problem in mbed library. And came to concludion that the bug is in the firmware. I will not spend any more time on this, will use another usb to serial converter and another port if necessary.
posted by Jurgis Jurksta 15 Apr 2015
