10 years, 11 months ago.
NTP current time
hello i want read the computer current time and then shown it on the LPC1768 LCD through the cable, and i just import a code but the mbed cant get the IP address, and finally the time is not the real time, can somebody help me
app_board-NTPclock
#include "NTPClient.h"
#include "C12832_lcd.h"
C12832_LCD lcd; //Graphics LCD
EthernetInterface eth;
NTPClient ntp;
eth.init(); //Use DHCP
wait(2);
lcd.cls();
lcd.printf("Getting IP Address\r\n");
if(eth.connect(60000)!=0) {
lcd.printf("DHCP error - No IP");
wait(10);
} else {
lcd.printf("IP is %s\n", eth.getIPAddress());
wait(2);
lcd.cls();
lcd.printf("Trying to update time...\r\n");
if (ntp.setTime("0.pool.ntp.org") == 0) {
lcd.printf("Set time successfully\r\n");
lcd.cls();
lcd.locate(0,0);
time_t ctTime;
ctTime = time(NULL);
lcd.printf("%s\r\n", ctime(&ctTime));
lcd.printf("Current Time (UTC)");
wait(1);
} else {
lcd.printf("NTP Error\r\n");
eth.disconnect();
is your mbed connected to internet ? in that case try with an ststic ip address if your computer or ethernet switch doesn't provide an dhcp address to your mbed.
Hello, my computer shows that the mbed has been connected, but the IP address is unavailable. i can show you the statement.
If you want Mac Os X to give an dynamic address Ip to the mbed you have to enable Sharing Internet connection through the preferences menu.
You can also do in another way : set an static ip adress to the mbed with the init() function as :
eth.init("192.168.1.99", "255.255.255.0", "192.168.1.xx");
where xx is the ip of your mac computer (the wifi one). This is true if your network is in the 192.168.1.zzz network
the args of the init command are :
/ Initialize the interface with a static IP address.
- Initialize the interface and configure it with the following static configuration (no connection at this point).
- \param ip the IP address to use
- \param mask the IP address mask
- \param gateway the gateway to use
- \return 0 on success, a negative number on failure
- / static int init(const char* ip, const char* mask, const char* gateway);
you can find it : http://developer.mbed.org/users/mbed_official/code/EthernetInterface/file/2fc406e2553f/EthernetInterface.h
posted by 13 Apr 2015
