10 years, 11 months ago.
LPC4088 quick start board - Xbee module configuration
I compiled default XBee program for LPC4088 quick start board and it is not working because I need 2 LPC4088 quick start boards which I don't have. Is there any way I can modify this program in order to send information directly form XBee which is on the LPC4088 to the XBee connected directly to my PC terminal application?
For terminal application I use "minicom" and have set up serial port to be 9600 8N1 which means 9600 baud rate, 8 data bits no parity and 1 stop bit. By the way what are the default UART settings for the XBee example? I would like to recieve any kind of character from LPC4088 directly to PC terminal app... How can I do that?
default LPC4088 quick start board XBee example
 * Includes
#include "XBee.h"
 * Typedefs and defines
// define NODE_IS_COORDINATOR if this board should act
// as XBee coordinator. Make sure it is undefined it the board
// should act as End-Device
#define NODE_IS_COORDINATOR (1)
#define CMD_BTN_MSG (0)
#define CMD_ACK_MSG (1)
 * Local variables
static XBee xbee(P4_22, P4_23, P4_17, P4_19);
// led1 + led 2 -> active low
static DigitalOut xbeeInitLed(LED1);
static DigitalOut remoteBtnLed(LED2);
// led3 + led 4 -> active high
static DigitalOut ackLed(LED3);
static DigitalOut led4(LED4);
static DigitalIn button(p23);
static bool xbeeIsUp = false;
 * Local functions
static void xbeeDeviceUp(void) {
    xbeeIsUp = true;
static void xbeeDeviceDown(void) {
    xbeeIsUp = false;
static void xbeeNodeFound(void) {
    uint32_t addrHi = 0;
    uint32_t addrLo = 0;
    uint8_t rssi = 0;
    xbee.getRemoteAddress(&addrHi, &addrLo);
    xbee.getRssi(&rssi);
    printf("XBee: node found: hi=%lx, lo=%lx, rssi=%d\n",
            addrHi, addrLo, rssi);
static void xbeeTxStat(void) {
    uint8_t frameId = 0;
    XBee::XBeeTxStatus status = XBee::TxStatusOk;
    xbee.getTxStatus(&frameId, &status);
    printf("XBee: Tx Stat. Id=%u, status=%d\n", frameId, (int)status);
static void xbeeDataAvailable(void) {
    char* data = NULL;
    char ackMsg = CMD_ACK_MSG;
    uint8_t len = 0;
    uint8_t rssi = 0;
    xbee.getData(&data, &len);
    printf("XBee: Data available: len=%d hi=%lx, lo=%lx, rssi=%d\n",
            (int)len, addrHi, addrLo, rssi);
    if (len > 0) {
        switch(data[0]) {
        case CMD_BTN_MSG:
            if (len > 1) {
                // change led to indicate button state
                remoteBtnLed = ((data[1] == 1) ? 1 : 0);
                // Send an ACK directly to the remote node (only for
                // buttons state == 0)
                if (data[1] == 0) {
                    xbee.send(addrHi, addrLo, &ackMsg, 1, &frameId);
            break;
        case CMD_ACK_MSG:
            for (int i = 0; i < 3; i++) {
                ackLed = 1;
                wait_ms(100);
                ackLed = 0;
                wait_ms(100);
            break;
static bool xbeeInit()
    xbee.registerCallback(xbeeDeviceUp, XBee::CbDeviceUp);
    xbee.registerCallback(xbeeDeviceDown, XBee::CbDeviceDown);
    xbee.registerCallback(xbeeNodeFound, XBee::CbNodeFound);
    xbee.registerCallback(xbeeTxStat, XBee::CbTxStat);
    xbee.registerCallback(xbeeDataAvailable, XBee::CbDataAvailable);
#ifdef NODE_IS_COORDINATOR
    XBee::XBeeError err = xbee.init(XBee::Coordinator, "EAEA");
#else
    XBee::XBeeError err = xbee.init(XBee::EndDevice, "EAEA");
#endif
    if (err != XBee::Ok) {
        return false;
    return true;
static void reportInitFailed() {
    while (true) {
        xbeeInitLed = !xbeeInitLed;
        wait_ms(200);
static void ledInit() {
    xbeeInitLed = 0;  // turn on
    remoteBtnLed = 1; // turn off
    ackLed = 0;       // turn off
    led4 = 0;         // turn off
 * Main function
     * For this example to work at least two boards with XBee nodes must
     * be available; one which is configured as Coordinator and another
     * which is configured as End-Device.
     * LED1 shows the state of XBee initialization. This LED is turned
     * on when initialization starts and turned off when initialization
     * is ready and the device us up. If initialization fails LED1
     * will blink.
     * When the Push-button on the LPC4088 QuickStart Board is pushed
     * a message will be broadcasted. The board(s) that receives the message
     * will show the state of the remote board's button by turning LED2
     * on or off.
     * The board that receives the button state message will send back
     * an ACK message (only for button down). The board that receives
     * the ACK message will blink with LED3. This can be used to verify
     * that a board that is not close to you actually received a message
     * without having to look at that board's LED2.
    int buttonState = 1;
    char data[2];
    // pull-up must be enabled for button
    button.mode(PullUp);
    ledInit();
    printf("Initializing\n");
    if (!xbeeInit()) {
        reportInitFailed();
    // Wait until XBee node is reported to be up.
    // - For End-device this means that the node is associated with a
    //   coordinator
    // - For a coordinator this means that the node is initialized and ready
    printf("Wait until up\n");
    while(!xbeeIsUp) {
        xbee.process();
    // turn off led to indicate initialization is okay and node is up
    xbeeInitLed = 1;
    printf("Node is Up\n");
    while (1) {
        if (button != buttonState) {
            buttonState = button;
            data[0] = CMD_BTN_MSG;
            data[1] = buttonState;
            // Send the button state. In this example we are broadcasting the
            // message to all nodes on the same network (PAN ID). In reality
            // direct messaging is preferred.
            xbee.send(XBEE_ADDRHI_BROADCAST, XBEE_ADDRLO_BROADCAST,
                    data, 2, &frameId);
        xbee.process();
-deleted-
This is a fun test.
You may need a USB adapter module:
http://www.adafruit.com/products/247
or https://www.parallax.com/product/32400
or https://www.sparkfun.com/products/11812
You could use Python or Java on the PC side:
http://code.google.com/p/python-xbee/
or http://code.google.com/p/xbee-api/
