11 years ago.
How to use D0 pin ?
dear Erik / Embed team I am planning to connect D0-D15 to LCD data lines to my 3.2inch graphics LCD with touch panel if I connect D0-D15 directly to LCD data lines it would be better I guess at the same time I will need STLink for debug, pls suggest connections achieve the above 2 requirements
Thanks is advance
11 years ago.
You can use ports pins on the Morpho headers (rows from the outside side of board). There are a lot of free pins that you can use exactly the same manner as "arduino" pins for you display.
