9 years, 6 months ago.
Can i use Timer and Ticker together?
I am using the ticker to make a square wave that can be used as a step input for a stepper motor. I am working in the range of 1kHz to 25 kHz and i wanted to see how this effects the rest of the main thread. Can i use timer for this or will using ticker and timer together give me unreliable results?
I attached a part of the code below that may explain my question better.
Note: The POT is just for testing, i don't plan on keeping it there.
example
DigitalOut pin7(D7);
AnalogIn readPOT(A0);
void trigger_step() {
pin7 = !pin7;
while (true) {
timer.start();
//pc.printf("This program runs since seconds.\n");
pc.printf("A0 reads: %f \n", readPOT.read()); //analog read returns between 0-1 at 12bit resolution
stepspeed = (readPOT.read() * 22000);
timeperiodmicro = (1/stepspeed)*0.5*1000000; //Multiply by 0.5 for half period for 50% duty cycle
toggle_step_ticker.attach_us(&trigger_step, timeperiodmicro);
pc.printf("Time Period: %f \n", timeperiodmicro);
pc.printf("Time in micro seconds : %f \n", timer.read_us());
timer.stop();
Ticker does not affect Timer in any way. However I would replace the Ticker with PWM here.
Thank you and I need to have 2 independent signals, from what i have seen from the forums changing the frequency on PWM changes the frequency for all PWM outputs?
posted by 21 Jul 2016It depends on your MCU how it works exactly. I see you got a F411? On the pinout the PWMs are labbeled as PWM1/2, where the first number is the timer and the second the channel. If you use two pins on different timers, they can have independent frequencies. Otherwise they are indeed equal.
