13 years, 4 months ago.
Is there any way to access the onboard EEPROM on the LPC11U24 ?
From the spec sheet of the 11u24 family, it looks like they all have some small amount of EEPROM built into them (1K-4K), is there a way to access this through a library or a good reason to not be allowed to use this feature of the 11u24 in the MBED config ?
Just found the answer, thanks to work done by Suga KouBou, he provided code to use the 11U24 IAP routines to access the eeprom, thank you Suga.
Hello, I use also the IAP function to write the EEPROM on an LPC11U24. it works fine, but I found an issue : I'm using at the same time a virtual com port on USB, and I found that the IAP EEPROM write call sometime (but rarely) never returns if the USB interrupt is enabled. Since I turned off the interrupt before the call, and back on after, the problem never occured again. Hope this helps. PP
