9 years, 9 months ago.
mbed SPI mode
Hi all, i've got a question about mbed SPI driver: if i change the peripheral working mode from to 0 to 2-3 (CPOL 1), the SCK pin shouldn't go high?
Thanks in advance.
The CPOL polarity defines the SCK level during idle periods: either high or low.
See here.
When you change the mode the pins should activate the new mode immediately.
Apparently there's something wrong.
I create a SPI object, change mode to 3 and write a cmd.
This is what i see on the bus /media/uploads/lucacirani/capture.jpg SCK stays high only after the first write.
I'm on frdm-k22f.
posted by User Name 14 Jul 2016
What value was actually written out? if the value was 0x80 then those waveforms would make sense. I would guess that the clock is "lazy" meaning it only updates when a transition is required and we're not seeing the initial falling edge at t=-0.5bit because the clock was already low.
posted by Oliver Broad 14 Jul 2016
