9 years, 8 months ago.
Is it possible to use a variable without using the pins directly
My intention is to use an array to store the pins. In my codes, then i use these arrays to configure the pins as input or output so that the DigitalOut or DigitalIn etc is independent of the pins.
I'd tell you look up for the macro that refers to the port of the micro-controller that you want to use, and then assign it a value stored in a variable or read its value directly, but it's kinda of rough. Why don't you use DigitalInOut instead ? Should do the trick.
