9 years, 6 months ago.
Why does the LPC1768 sleep() function prolong timer interrupts?
I have the following program, that just blinks an LED on the application board every 2ms using a busy-loop:
#include "LPC17xx.h"
#define TICK_TIME_US (2000)
static volatile bool tick_lapsed = false;
void handle_timer()
tick_lapsed = true;
DigitalOut led(p23);
Ticker ticker;
ticker.attach_us(handle_timer, TICK_TIME_US);
do
while(!tick_lapsed);
led = !led;
} while(true);
return 0;
I've checked with a logic analyser, and the pulse width is indeed 2ms (4ms total period).
But if I change the busy loop to a sleep call:
do
while(!tick_lapsed)
sleep();
led = !led;
} while(true);
...then the pulse width blows out to 10ms!
I was under the impression that timers should still run during the LPC's sleep mode. How can I configure them to interrupt every 2ms? Even configuring TIMER0 using the registers manually results in nothing below 10ms.
