9 years, 6 months ago.
I get a .bin file in the download library when I compile.
When I compile I get .BIN file in the download file. Several years I ask the same Question and ended up using the Kiel C++ compiler to get a .HEX file. I no longer have access to the Kiel Compiler. Is there a solution to this problem Using the MBed 1768 board. Martin Potts
Several different bin2hex utilities exist that are all pretty much the same, only with different size limitations (some are so old they are limitted to 16-bit binary sizes and stuff like that).
For example: https://developer.mbed.org/questions/1147/Bin2Hex-Utility-for-64bit-Windows-7/
Do you absolutely need the file in HEX form? The MBED accepts "BIN" and the tool lpc21isp will serial-load a BIN file onto a 1768
posted by Oliver Broad 25 Jun 2016
