10 years, 11 months ago.
what is different pwm?(Nucleo-F411RE)
Hello, I want to know difference of PWM pin in Nucleo-F411RE.
when I see the Arduino-compatible headers, there are many PWM pins in board.
but, I don't know why they are expressed PWM4/1, PWM4/3, PWM4/4.....etc?
Each of the other functions do they?
Please.... TT
First number is the timer they use: Each PWM on the same timer will have the same period. Second one is the channel of that timer they use: If two pins both have PWM4/1, they will always have exactly the same pulsewidth if you both use them as PWM. (Also by the way don't use channel 1 and channel 1N on the same timer at the same time for different pins). If they are on different timers you don't need to worry and can use them independently.
oh!!!! Thank you!!! I understand!!!!!!
posted by Byeon SangGyu 03 Apr 2015
