9 years, 6 months ago.
Wiring a MPR 121 capacitive touch keypad to LPC 1768
Plz can someone provide the schematics to connect MPR 121 capacitive touch keypad to a LPC 1768
Looks like a fairly ordinary I2C device so try picking any MBED I2C port such as P27 SCL, P28 SDA and add 10K pull-up resistors from both pins to VOUT (3.3V).
Then connect MBED GND to keypad GND and MBED VOUT to keypad VCC, SDA to SDA, SCL to SCL.
You usually don't have to use "INT" if you read the keypad often enough.
will it work if I use 4.7k pull ups
posted by nipuna wickramasinghe 31 May 2016
Should do, I2C is pretty tolerant unless you are trying to go very fast or long distance.
This probably tells you more than you wanted to know about determining the resistors: http://www.ti.com/lit/an/slva689/slva689.pdf
posted by Oliver Broad 31 May 2016
