11 years ago.
Single Byte read
Hallo. Is there any special reason why there is no function for single byte read?
11 years ago.
You can use the multibyte read and set size to 1. The code for a single byte read would be just about identical and just makes the lib larger.
The code for single and multi byte write on the other hand has more differences. BTW a quick look at the code shows that multibyte write is probably not very efficiently implemented. The memory address is set again for each byte. This should be auto-incremented by the EEPROM.
Great. I will look forward to optimize multi byte write and make a pull request. Will take some time until my pcbs arrive. Do you recommend any other lib for 24LC64 as a "standard"?
posted by 01 Apr 2015The component page has some examples https://developer.mbed.org/components/cat/storage/
posted by 01 Apr 2015The multibyte write didn't work as it didn't recognized page size. (You can not write over the page border). We have cleaned up and added a correct multibyte write to the library here: http://developer.mbed.org/teams/Akafugu/code/_24LCXXX/
Pull requests are pending.
posted by 15 Apr 201510 years, 11 months ago.
Thank you everyone.
I'm not familiar with how to use the mbed web. I published a half-hearted Archives that made the time being. It seems to have become as they left the state.
Like I have in the code that was written there was a bug. I am grateful. you for correction.
