9 years, 10 months ago.
LMiC bug
Hello everyone!
I am currently testing the LMiC App (code LoRaWAN-lmic-app from Semtech) with the NUCLEO-L073RZ board and the SX1276MB1MAS shield.
I noticed that the program occasionally get stuck so I decided to add some debug lines to figure it out. The program is always stuck between the sending of a frame and the check of the last RX window.
Here is the modified piece of code for debugging:
//======================================== Data frames
// Fwd decl.
static bit_t processDnData(void);
static void processRx2DnDataDelay (xref2osjob_t osjob) {
pc_lmic.printf("?\r\n");
processDnData();
static void processRx2DnData (xref2osjob_t osjob) {
pc_lmic.printf("? ");
if( LMIC.dataLen == 0 ) {
LMIC.txrxFlags = 0; // nothing in 1st/2nd DN slot
// Delay callback processing to avoid up TX while gateway is txing our missed frame!
// Since DNW2 uses SF12 by default we wait 3 secs.
pc_lmic.printf("RX2 delayed");
os_setTimedCallback(&LMIC.osjob,
(os_getTime() + DNW2_SAFETY_ZONE + rndDelay(2)),
processRx2DnDataDelay);
return;
processDnData();
static void setupRx2DnData (xref2osjob_t osjob) {
pc_lmic.printf("RX2");
LMIC.osjob.func = FUNC_ADDR(processRx2DnData);
setupRx2();
static void processRx1DnData (xref2osjob_t osjob) {
if( LMIC.dataLen == 0 || !processDnData() )
schedRx2(DELAY_DNW2_osticks, FUNC_ADDR(setupRx2DnData));
static void setupRx1DnData (xref2osjob_t osjob) {
pc_lmic.printf("RX1");
setupRx1(FUNC_ADDR(processRx1DnData));
static void updataDone (xref2osjob_t osjob) {
pc_lmic.printf("[LMIC] Check RX windows... ");
txDone(DELAY_DNW1_osticks, FUNC_ADDR(setupRx1DnData));
Here is the result:
[MAIN] Preparing TX frame... [MAIN] PORT = 0000000F [MAIN] DATA SIZE = 00000008 [MAIN] FRAME = 01 00 04 00 03 FF A9 24 [LMIC] Looking for another suitable channel... Done! (TX on channel 2 in 84.2 s) [LMIC] Frame sent with DR0 (SeqNoUp = 00000005) [LMIC] Check RX windows... RX1? RX2? RX2 delayed? [LMIC] Looking for another suitable channel... Done! (TX on channel 0 in 140.9 s) [LMIC] Frame sent with DR0 (SeqNoUp = 00000005) [LMIC] Check RX windows... RX1? RX2? RX2 delayed? [LMIC] Looking for another suitable channel... Done! (TX on channel 1 in 140.1 s) [LMIC] Frame sent with DR0 (SeqNoUp = 00000005) [LMIC] Check RX windows... RX1? RX2? RX2 delayed? [LMIC] Looking for another suitable channel... Done! (TX on channel 2 in 139.9 s) [LMIC] Frame sent with DR0 (SeqNoUp = 00000005) [LMIC] Check RX windows... RX1? RX2? RX2 delayed? [LMIC] Looking for another suitable channel... Done! (TX on channel 0 in 140.5 s) [LMIC] Frame sent with DR0 (SeqNoUp = 00000005) [LMIC] Check RX windows... RX1? RX2? RX2 delayed? [LMIC] Looking for another suitable channel... Done! (TX on channel 1 in 139.5 s) [LMIC ] Frame sent with DR0 (SeqNoUp = 00000005) [LMIC] Check RX windows... RX1 // Program stuck
The problem is consequently in the setupRx1() function, which apparently does not call the processRx2DnData job. I noticed that the data processing job was treated separately for the RX2 window and I tried to use the same process for RX1 but this time the programm got stuck by RX2. Then I tried to apply the RX1 process to RX2 but without success...
I would like to know if any of you had this problem and fixed it or if someone could see where the error could be.
Thank you!
