9 years, 5 months ago.
Problem with FRDM KL25Z!!
Hy.I'm using a freedom board,KL25z and I have some problems with it...I tried to update the bootloader from 1.09 to 1.11. Steps I followed: 1.Connect board with reset button pressed. 2.Copy bootloader file. 3.Unplug board,replug board. 4.Open SDA_Info and still 1.09 version.
And if i want to install mbed firmware, i get this: Board Name is: FRDM-KL25Z MicroBoot Kernel Version is: 1.05 Bootloader Version is: 1.09 Application Version is: 0.00 DUID is: 41233938-ADD681BE-377C2809-B860E678 EUID is: 39C1A239-3F748750-187D4A1E-925968D6 TUID is: 74823938-473281D6-3764981C-B85CE678 TOA is: 86B6E505-9D86B4A2-41E6B687-9A92E763 TOA2 is: 86B6E505-326C40C1-CDE430D7-4E27E814 SUID is: 86B6E505-6C47A61D-37239804-8003EC65
If I want to install MSD-DEBUG-FRDM-KL25Z_Pemicro_v118, I get this: Board Name is: FRDM-KL25Z MicroBoot Kernel Version is: 1.05 Bootloader Version is: 1.09 Installed Application: PEMicro FRDM-KL25Z Mass Storage/Debug App Application Version is: 1.18 DUID is: 41233938-ADD681BE-377C2809-B860E678 EUID is: 39C1A239-3F748750-187D4A1E-925968D6 TUID is: 74823938-473281D6-3764981C-B85CE678 TOA is: 86B6E505-9D86B4A2-41E6B687-9A92E763 TOA2 is: 86B6E505-326C40C1-CDE430D7-4E27E814 SUID is: 86B6E505-6C47A61D-37239804-8003EC65. And if i connect board to pc normally, opens the bootloader without reset button pressed. I installed all firmware i found on the internet and still nothing.... I'm using windows 7 and i dont know what to do for my board to work again....Sorry for bad english
