9 years, 8 months ago.
Can I control the level of optimization of the compiler?
Basically what the title says.. Is this possible? In order to avoid over optimization??
This may helps.
http://infocenter.arm.com/help/topic/com.arm.doc.dui0472l/chr1359124984478.html
#pragma O0 // makes minimum optimization level.
Please note that mbed online compiler option is -O3 -Otime by default.
https://github.com/mbedmicro/mbed/blob/master/workspace_tools/toolchains/arm.py
Thanks I ll try it it work (it is a letter "O" followed by a zero :)
unfortunately it did not solve my problem. Thanks again
posted by Cristian Fuentes 19 May 2016
I don't know if this is possible in the online compiler, but if you export to GCC ARM then you can control optimisations by editing the CC_FLAGS variable in the Makefile.
Perhaps this isn't exactly what you are looking for but in some situations it could help:
By declaring a variable as volatile one can prevent the compiler from optimizing the code associated with that variable.
I also had an variable which has been changed by an interrupt handler and a main while loop was not existing, the volatile solved it.
posted by Helmut Tschemernjak 19 May 2016
Thank you, Yes, so far I have been solving problems like this with volatile, just as Helmut says.
posted by Cristian Fuentes 20 May 2016
