9 years, 8 months ago.
mdot library hangs on joinNetwork() fuction.
I have a problem with mDot board hanging on the call to to the joinNetwork() method. I have the following code:
pc.printf("joining network ");
if (!dot->getNetworkJoinStatus()) {
pc.printf("(network not joined, joining network) ");
if ((ret_value = dot->joinNetwork()) != mDot::MDOT_OK) {//Hangs here
pc.printf("failed to join network %d:%s\n\r", ret_value, mDot::getReturnCodeString(ret_value).c_str());
while(true){}
else{
pc.printf("network joined successfully\n\r");
else{
pc.printf(" Network already joined!\n\r");
I have set the configuration into the flash memory using the AT firmware and my connection method is set to AUTO_OTA and the configuration memory seems to be preserved as I can upload the AT firmware back to the device and use it to confirm the configuration. Am I missing something pretty obvious here?
