9 years, 11 months ago.  This question has been closed. Reason: Unclear question
mbed crashing on deleted code
I've been trying to implement a watchdog timer into my code, used an implementation I found online and compiled my project. My device crashed as soon as the code started, so I assume there's a mistake somewhere. Deleted the code from my implementation and put it on my device, just make sure it wasn't a hardware issue and it crashes. It was working before.
I go to the revisions menu and it shows no changes from my last commit. I reverted to a previous version, ran it and it worked. I switched to the most recent version (which previously hadn't worked) and it ran fine.
If I add in the watchdog code, even if it isn't called, then nothing which the mbed compiler compiles will run until I revert my code in the revisions menu. The code can be 100% identical and contain no trace of the watchdog code I wrote, but it'll still crash until I revert.
#include "Watchdog.h"
void Watchdog::feed(float s) {
    LPC_WDT->WDCLKSEL = 0x1;
    uint32_t clk = SystemCoreClock / 16;
    LPC_WDT->WDTC = s * (float)clk;
    LPC_WDT->WDMOD = 0x3;
    feed();
void Watchdog::feed() {
    LPC_WDT->WDFEED = 0xAA;
    LPC_WDT->WDFEED = 0x55;
