9 years, 10 months ago.
Export to KDS, Problem with RTOS for Platform K64F
Hey Community,
I want to export a simple RTOS project with SDFileSystem library.
If I compile the online version - it's fine :)
But If I compile with Kinetis Design Studio KDS 3.0 - the binary seems to be okay, but I can not use SD-Card functions. The Compile output is without warnings or errors...
RTOS Crashes If I use fprintf() functions within Threads. If I use fprintf() functions outside Threads, (for e.g. in main init()) it is working well !
( the Assembler files are S. renamed)
Why does the RTOS behave different from the online compiled version??
Thanks to all :)
we need more information please. Wht's the version of the library - rtos and mbed ? there was a change to new RTX recently. Does it work with older (2 revision back for instance) ?
posted by Martin Kojtal 10 May 2016
RTOS is Rev 107 MBED is rev 116
posted by Tobi Roe 11 May 2016
If I update all libraries to current version, then EthernetInterface doesnt compile ( K64F Bug). Cannot open source file "fsl_enet.h"
Like: https://developer.mbed.org/questions/68935/Latest-mbed-rtos-breaks-Ethernet-on-K64F/
Problem SOLVED :) With the help of this topic: https://developer.mbed.org/forum/mbed/topic/3290/
Increased stack size for thread to 2.25 * DEFAULT_STACK_SIZE
posted by Tobi Roe 12 May 2016
