9 years, 10 months ago.
mbed TOOLCHAIN_ARM_MICRO and ARM_STD dfference?
When investigating into the mbed source I see that there are two different targets (MICRO and STD), I understand that the online compiler uses the MICRO target for the Nucleo/Disco boards.
What is the difference between MICRO and STD? Can I switch within mbed to STD?
Thanks for the advise.
you can't switch. It's set by default for a target (default_toolchain in the targets.py script file). The recommendation is to use uLib for devices <64k of the Flash, otherwise it should use full std library. T
o compare those to, look at http://www.keil.com/arm/microlib.asp
