11 years ago.
fopen local file system not working
Having issues with fopen when trying to open a file in binary mode. When using binary mode the *fp pointer returns NULL every time. The file to open does exist and is located on the local file system. What am I doing wrong?
This fails
#include "LPC17xx.h" /* LPC17xx definitions */
#include "PPD_CAN.h"
#include "rtos.h"
#include <iostream> // library that contain basic input/output functions
#include <fstream> // library that contains file input/output functions
using namespace std;
//Open binary file to write
FILE *fp = fopen(PATH_TO_BINARY, "rb"); // This fails and returns NULL every pass
if (fp == NULL) {
pc.printf("Failed to open binary.\n");
return -1;
} else {
pc.printf("File opened successfully\n");
//Get some work done here
fclose(fp);
This works
#include "rtos.h"
FILE *fp = fopen(PATH_TO_BINARY, "r"); // This works every pass
if (fp == NULL) {
return -1;
} else {
fclose(fp);
6 years, 11 months ago.
Hi Rob - did you ever manage to get to the bottom of this problem? I may be encountering a similar issue...
Just tried the following which also does not work when Binary mode is used. Is this a bug? Is the local file system not accessible when reading a file as a binary.
Does not work
streampos size; char * memblock; ifstream file ("/local/data.BIN", ios::in|ios::binary|ios::ate); if (file.is_open()) { size = file.tellg(); memblock = new char [size]; file.seekg (0, ios::beg); file.read (memblock, size); file.close(); cout << "the entire file content is in memory"; delete[] memblock; } else cout << "Unable to open file" << endl;
