11 years ago.
Max Ethernet Frame Size ?
Hi Community,
I stumbled upon a problem with sending Ethernet frames. The maximum size I can achieve with the mbed library is 768 bytes, but I want to send the maximum size of 1536 bytes.
#include "mbed.h" Ethernet eth; int test1 = eth.write(buf_send,769);
test1 will return '-1' if the buffer is larger than 768bytes. Does somebody know how to fix this limitation ?
I found this thread: http://developer.mbed.org/questions/946/Use-of-Ethernet-class-write-send-methods/
but the solution there doesn't work anymore, so I wanted to ask here if somebody has a clue.
Thanks in advance
