9 years, 10 months ago.
4D systems display with EFM32 Leopard Gecko
Hi, I have found a library on mbed in C++ and successfully interfaced 4D Systems display with EFM32LG-STK3600 kit. Now I'm trying to do the same thing in C using SiLabs built in libraries and drivers from emlib, CMSIS and common kit drivers.
I have made changes and used RTC driver to perform same function as Timer API on mbed. My code gets compiled successfully but it's not working as expected. It was working before when I compiled using online mbed compiler and C++ library.
Please kindly help as I am stuck with this problem and also asked for the solution on SiLabs forums.
Thanks. /media/uploads/shakeeb/uart_visi.c /media/uploads/shakeeb/visi_genie.c /media/uploads/shakeeb/visi_genie.h
Hi Syed,
you'll have to provide some more information for us to go on, other than "it's not working as expected". What exactly is not working? What erroneous behaviour are you seeing?
posted by Steven Cooreman 25 May 2016Thanks for your reply Steven. Everything is working perfectly now. I'll ask again if any issue arises later on.
posted by Syed Shakeeb Sadiq 25 May 2016
