9 years, 10 months ago.
SX1276PingPong demo on modtronix inAir9
Hello I am trying to build a LoRa communication module for an IOT project. The hardware I use is listed below
NZ32-SC151 with STM32L151RC: http://modtronix.com/nz32-sc151
SX1276 inAir9: http://modtronix.com/inair9.html
Hardware were connect to iMod2 ports as shown like this:
I am using
Import librarymbed_nz32sc151
mbed library for NZ32-SC151
and
Import librarySX1276Lib_modtronix
Enabled all bandwidths, added Modtronix inAir9 module
However, when using demo code similar to https://developer.mbed.org/teams/Semtech/code/SX1276PingPong/, some problems were noticed:
- With Rx timeout set to 3500000us, Tx timeout set to 2000000us, the program returns "OnTxTimeout" and "OnRxTimeout" in order. There is no RF signal transmitted and received.
Anyone have ideas about this problem?
Thanks
The code is shown below:
Example Code
#include "sx1276Regs-LoRa.h"
#include "sx1276-inAir.h"
#define DEBUG 1
#define RF_FREQUENCY 868700000 // 868KHz
#define TX_OUTPUT_POWER 14 // 14 dBm for inAir9
#define LORA_BANDWIDTH 7 // 0: 7.8 kHz, 1: 10.4 kHz, 2: 15.6kHz, 3: 20.8kHz,
// 4: 31.25kHz, 5: 41.7 kHz, 6: 62.5 kHz,
// 7: 125 kHz, 8: 250 kHz, 9: 500 kHz
#define LORA_SPREADING_FACTOR 12 // SF7..SF12
#define LORA_CODINGRATE 1 // 1=4/5, 2=4/6, 3=4/7, 4=4/8
#define LORA_PREAMBLE_LENGTH 8 // Same for Tx and Rx
#define LORA_SYMBOL_TIMEOUT 5 // Symbols
#define LORA_FIX_LENGTH_PAYLOAD_ON false
#define LORA_FHSS_ENABLED false
#define LORA_NB_SYMB_HOP 4
#define LORA_IQ_INVERSION_ON false
#define LORA_CRC_ENABLED true
#define TX_TIMEOUT_VALUE 2000000
#define RX_TIMEOUT_VALUE 3500000 // in us
#define BUFFER_SIZE 32 // Define the payload size here
void OnTxDone(void);
void OnTxTimeout(void);
void OnRxDone(uint8_t *payload, uint16_t size, int16_t rssi, int8_t snr);
void OnRxTimeout(void);
void OnRxError(void);
Serial pc(USBTX, USBRX); //Use default TX and RX. Available via USB Com port when using PGM-NUCLEO programmer
SX1276inAir radio(OnTxDone, OnTxTimeout, OnRxDone, OnRxTimeout, OnRxError, NULL, NULL);
DigitalOut led(LED1);
uint8_t Buffer[BUFFER_SIZE];
uint16_t BufferSize = BUFFER_SIZE;
int16_t LoRaRssi;
int8_t LoRaSNR;
volatile RadioState State = LOWPOWER;
const uint8_t PingMsg[] = "PING";
const uint8_t PongMsg[] = "PONG";
void OnTxDone(void)
radio.Sleep();
State = TX_DONE;
#if DEBUG == 1
pc.printf("OnTxDone\r\n");
#endif
radio.Sleep();
State = TX_TIMEOUT;
#if DEBUG == 1
pc.printf("OnTxTimeout\r\n");
#endif
radio.Sleep();
BufferSize = size;
memcpy(Buffer, payload, BufferSize);
LoRaRssi = rssi;
LoRaSNR = snr;
State = RX_DONE;
#if DEBUG == 1
pc.printf("OnRxDone\r\n");
#endif
radio.Sleep();
Buffer[BufferSize] = 0;
State = RX_TIMEOUT;
#if DEBUG == 1
pc.printf("OnRxTimeout\r\n");
#endif
radio.Sleep();
State = RX_ERROR;
#if DEBUG == 1
pc.printf("OnRxError\r\n");
#endif
wait_ms(500); // start delay
// configure uart port
pc.baud(19200);
pc.format(8, SerialBase::None, 1);
// configure radio
radio.SetBoardType(BOARD_INAIR9); // the correct hardware for our own board
led = 0;
while (radio.Read(REG_VERSION) == 0x00)
pc.printf("Trying to connect to radio device\r\n");
wait_ms(200);
led = 1;
pc.printf("Radio is initialized\r\n");
// set radio frequency
radio.SetChannel(RF_FREQUENCY);
// setup the modern
radio.SetTxConfig(
MODEM_LORA,
TX_OUTPUT_POWER,
0,
LORA_BANDWIDTH,
LORA_SPREADING_FACTOR,
LORA_CODINGRATE,
LORA_PREAMBLE_LENGTH,
LORA_FIX_LENGTH_PAYLOAD_ON,
LORA_CRC_ENABLED,
LORA_FHSS_ENABLED,
LORA_NB_SYMB_HOP,
LORA_IQ_INVERSION_ON,
TX_TIMEOUT_VALUE
radio.SetRxConfig(
MODEM_LORA,
LORA_BANDWIDTH,
LORA_CODINGRATE,
0,
LORA_SYMBOL_TIMEOUT,
0,
LORA_CRC_ENABLED,
LORA_FHSS_ENABLED,
LORA_NB_SYMB_HOP,
true
uint8_t i;
bool isMaster = true;
radio.Rx(RX_TIMEOUT_VALUE);
while (1)
// Check for connection to radio module
led = !led;
pc.printf("Reconnecting...\r\n");
wait_ms(200);
led = 1;
switch(State)
case RX_DONE:
if (isMaster)
if (BufferSize > 0)
if (strncmp((const char *)Buffer, (const char *)PongMsg, 4) == 0)
pc.printf("...Pong\r\n");
// send next ping frame
strcpy((char *)Buffer, (char *)PingMsg);
// fill the buffer with numbers for the payload
for( i = 4; i < BufferSize; i++ )
Buffer[i] = i - 4;
wait_ms( 10 );
radio.Send( Buffer, BufferSize );
else if (strncmp( ( const char* )Buffer, ( const char* )PingMsg, 4 ) == 0 )
// A master already exists then become a slave
pc.printf("...Ping\r\n");
isMaster = false;
// send the next pong frame
strcpy( ( char* )Buffer, ( char* )PongMsg );
// We fill the buffer with numbers for the payload
Buffer[i] = i - 4;
wait_ms( 10 );
else
isMaster = true;
else
if (BufferSize > 0)
if( strncmp( ( const char* )Buffer, ( const char* )PingMsg, 4 ) == 0 )
pc.printf( "...Ping\r\n");
// Send the reply to the PING string
Buffer[i] = i - 4;
wait_ms( 10 );
else // valid reception but not a PING as expected
{ // Set device as master and start again
isMaster = true;
radio.Rx( RX_TIMEOUT_VALUE );
State = LOWPOWER;
break;
case TX_DONE:
if (isMaster)
pc.printf("Ping...\r\n");
else
pc.printf("Pong...\r\n");
State = LOWPOWER;
break;
case RX_TIMEOUT:
if( isMaster == true )
// Send the next PING frame
strcpy( ( char* )Buffer, ( char* )PingMsg );
Buffer[i] = i - 4;
wait_ms( 10 );
else
State = LOWPOWER;
break;
case TX_TIMEOUT:
State = LOWPOWER;
break;
case RX_ERROR:
// We have received a Packet with a CRC error, send reply as if packet was correct
Buffer[i] = i - 4;
wait_ms( 10 );
else
// Send the next PONG frame
Buffer[i] = i - 4;
wait_ms( 10 );
State = LOWPOWER;
break;
case LOWPOWER:
break;
default:
State = LOWPOWER;
break;
Hi there, did you ever resolve this issue?
posted by Ruben FitzSimons 12 Feb 2017Hello Ruben We failed to solve the problem. It seems that three of our NZ32-SC151 boards were totally broken and unusable. Either way we didn't receive any help from Modtronix. In stead we hard wired the inAir9 module to NUCLEO-L152RE board. The demo worked as a charm and did not generate any error message.
posted by Ran Bao 13 Feb 2017
