9 years, 10 months ago.
Does DigitalOut have a second parameter?
From the handbook and header files I see that the DigitalOut constructor should take a second argument giving the initial pin state, and it appears to be an integer.
When I try this today (I'm convinced it compiled once yesterday) the line:
DigitalOut sel(p22,1);
fails with: Error: No instance of constructor "mbed::DigitalOut::DigitalOut" matches the argument list in "main.cpp", Line: 31, Col: 17
Is the documentation wrong or am I declaring it incorectly? I would prefer if the pin went straight to "high" as letting it default low then driving it high later could cause a false transition.
    /** Create a DigitalOut connected to the specified pin
     *  @param pin DigitalOut pin to connect to
     *  @param value the initial pin value
    DigitalOut(PinName pin, int value) : gpio() {
        gpio_init_out_ex(&gpio, pin, value);
Right mouse button on your mbed lib, click update. It should work, but it has been added a year ago or something, so older mbed versions do not have it.
OK: Still trying to work out how a new program would have an old lib?
I think I made the mistake of importing Serial_HelloWorld as a template so I have "inherited" the mbed libs from when that last updated. I also am stuck with my program showing as a fork of that example which it really isn't.
posted by Oliver Broad 19 Apr 2016
That indeed is the reason you have an old version, if you make a new program using the new button you do get the latest one automatically.
I don't know if there really is a way to break the 'fork of' thing without making a new program and copying your files there.
posted by Erik - 19 Apr 2016
