9 years, 11 months ago.  This question has been closed. Reason: Too broad - no single answer
yt login got login timeout
Q:when I input : yt login in the command line I get the respond from command line :
press enter to continue your browser will open to complete the login
then I login in the browser login page and get the follow page indication :
Woohoo!
Thanks for logging in - you're nearly done.
You can close this window and return to your console to check the login has been successful. tion If you're not logged in please run yotta login again.
and then I close the web page and return to the command line ,wait for about 5 mintes ,then it respond with login timeout error .
why this happen? thanks!
I filed a bug on the yotta project for you. Let's keep the discussion there. I pinged the yotta team about it as well.
posted by Jan Jongboom 20 Apr 2016
