9 years, 6 months ago.
Setting Registers on PHY chip using the FRDM-K64F
Hi Everyone,
I am attempting to directly modify the registers on the PHY chip on my FRDM-K64F board. The reason I would like to do this, is so that I can shutdown the PHY chip. Reading through the datasheets from both the PHY chip and the MK64F I think this should be possible by setting some of the registers. Here is the code I have come up with:
void PowerDownEthInterface(void){ // Powers down the Ethernet Interface unsigned int data = 0; unsigned int adr = 0x0; // The address of the PHY is either 0 or 3. // Turn on the ENET clock: SIM_SCGC2 |= SIM_SCGC2_ENET_MASK; // Enable the ENET: ENET_ECR |= ENET_ECR_ETHEREN_MASK; // Set the MII speed: ENET_MSCR |= (0x4) << ENET_MSCR_MII_SPEED_SHIFT; // Display some information: pc.printf("ENET_ECR: %d", ENET_ECR); // Build up the data register that will be sent to the PHY. // This uses information from Section 45.4.6 of the K64 Sub-Family Reference Manual, Document Number: K64P144M120SF5RM // Reset the data variable: data = 0; // Set bits 31 and 30 to 01 for a vlid MII management frame: data |= (0x1) << ENET_MMFR_ST_SHIFT; // Set the operation code (bits 29-28) to 0b01 = Write frame operation for a valid MII management frame data |= (0x1) << ENET_MMFR_OP_SHIFT; // Set the address of the PHY device to 0. There can be up to 32 devices. data |= (adr) << ENET_MMFR_PA_SHIFT; // Set the register address we would like to write to in the PHY. We want to set bit 11 in register 0, therefore set the address here to 0: data |= (0x0) << ENET_MMFR_RA_SHIFT; // Set the turn around bits to '10' for a valid MII frame: data |= (0x2) << ENET_MMFR_TA_SHIFT; // Set the data that will be written to the PHY device. For software power down, set bit 11 to 1: data |= ((0x1) << 11) << ENET_MMFR_DATA_SHIFT; // Send the data... pc.printf("Writing to ENET_MMFR..."); // Clear the MII write interrupt bit (writing a '1' clears the bit): ENET_MMFR &= ENET_EIR_MII_MASK; // Send the data to the PHY device by writing to the ENET_MMFR register: ENET_MMFR = data; // Check to see if it completes: while((ENET_EIR & ENET_EIR_MII_MASK) == 0); // Done! pc.printf("Writing to ENET_MMFR a success!"); // Put the MII back in a low power state: ENET_MSCR = 0; // Disable the ENET: ENET_ECR &= ~ENET_ECR_ETHEREN_MASK; // Turn off the ENET clock: SIM_SCGC2 &= ~SIM_SCGC2_ENET_MASK; return; }
Unfortunately, it does not seem to work. Furthermore, if you modify the appropriate registers above to read from the PHY chip, I do not read anything either.
Any thoughts?
Thanks,
Damien
