9 years, 11 months ago.
Storing some data
Hi
I am using the stm32f091rc processor on a custom board with the mbed library. Everything is working fine - but I just need to store some data that can be retrieved eve when powered off. Is a memory card the only option or is there a way to write to some of the flash memory.
I am a newbie if this is a silly question!!!!
many thanks!
It is possible to write to its own flash memory, the reference manual of your device can help, and/or the STM HAL files which are included in the mbed lib. However there is no easy to use library to do this for your MCU as far as I am aware. (I started it a while ago, but then found out it is different for all the STM targets, and it would have been hard to put it in one library).
Thanks! I notice that it has some backup registers with the RTC if you connect a battery.
RTC_HandleTypeDef RTCHandle
HAL_RCC_RTC_ENABLE(); PWR_CLK_ENABLE();
HAL_PWR_EnableBkUpAccess();
HAL_RTCEx_BKUPWrite(&RTCHandle,RTC_BKP0R,0x123456);
But the processor freezes on the write - anyone know why?
posted by Mark Evans 14 Apr 2016
Try putting the RTC_ENABLE after you enable the bckupaccess. Or just completely remove it, I don't know if you need that line.
By the way using <<code>> and <</code>> (on seperate lines) code gets formatted properly.
posted by Erik - 14 Apr 2016
