9 years, 8 months ago.
mbed development boards and pmod devices
Can I connect/use a Pmod device to/with a FRDM-K64F or other mbed compatible board? If not, what is the best way to connect a thermocouple to my FRDM-K64F?
Thanks. Guy
Assuming they work with 3.3V, sure that should work fine. If they require 5V supply it depends.
Thanks. It's this http://www.mouser.be/search/ProductDetail.aspx?r=700-MAX31855PMB1%23 Pmod device, so I suppose this will work. Is there a "better" way to connect a thermocouple to an mbed board (FRDM-K64F) then what I'm trying with the Pmod? Thanks.
posted by Guy Dillen 13 Apr 2016
I believe it isn't that hard to read out a thermocouple directly, but it depends on your requirements. If you want good accuracy then such a board is probably an easy way to get it. If you just want to measure your room temperature an DS1820 is an easier one.
posted by Erik - 13 Apr 2016
Ok thanks. I really need a thermocouple K-type, so the DS1820 is no option unfortunately. Do you know of any other similar boards as the one I showed? Thanks.
posted by Guy Dillen 14 Apr 2016
