9 years, 11 months ago.
How to use TCP echo Client on LPC4088DM Working with emWin
I use the TCPEchoClient example alone on LPC4088DM, it's can work. But when I use it on LPC4088DM working with emWin, it's broken. What's happen?
Did you modify the dm_board_config.h file ?
you have to uncomment the line about ethernet...
<<code>>
- Copyright 2014 Embedded Artists AB
- Licensed under the Apache License, Version 2.0 (the "License");
- you may not use this file except in compliance with the License.
- You may obtain a copy of the License at
- http://www.apache.org/licenses/LICENSE-2.0
- Unless required by applicable law or agreed to in writing, software
- distributed under the License is distributed on an "AS IS" BASIS,
- WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
- See the License for the specific language governing permissions and
- limitations under the License.
- ifndef DM_BOARD_CONFIG_H
- define DM_BOARD_CONFIG_H
Template to use for the project-specific settings. Copy this file to your project, rename it to dm_board_config.h and uncomment the wanted features below:
#define DM_BOARD_USE_USB_DEVICE #define DM_BOARD_USE_USB_HOST #define DM_BOARD_USE_MCI_FS #define DM_BOARD_USE_QSPI_FS #define DM_BOARD_USE_QSPI
- define DM_BOARD_USE_DISPLAY
- define DM_BOARD_USE_TOUCH #define DM_BOARD_USE_ETHERNET <- uncomment this line
- define DM_BOARD_USE_FAST_UART #define DM_BOARD_USE_USBSERIAL_IN_RTOSLOG #define DM_BOARD_DISABLE_STANDARD_PRINTF #define DM_BOARD_ENABLE_MEASSURING_PINS #define DM_BOARD_USE_REGISTRY
- endif <<code>>
