10 years ago.
I want to get angle using angular velocity of MPU9150 !
Hi I'm Ken! I want to get angle using angular velocity of MPU9150 ! I referred the MPU9150_Example which made by Mr.Chris Pepper. I'm waiting for comments! (^_^)Thank you!
What exactly do you mean with angle? Reading the values of the gyro should give you the angle of the board, which is covered in the example program: https://developer.mbed.org/users/onehorse/code/MPU9150AHRS/ (which you already seen I presume).
posted by Jan Jongboom 19 Apr 2016
Thank you for your response. But I couldn't compile that program. Because the N5110.lib which is necessary for compile doesn't exist! Thank you for your comment.
posted by Abe Smith 20 Apr 2016
