9 years, 11 months ago.
InterruptIn per pin number
I have found this post https://developer.mbed.org/questions/2737/Attaching-interrupt-to-pins-other-than-P/ and Erik Olieman said, that you can only have one interruptin per pin number, so if you make PC_5 an interrupt, you can not make PA_5 also one. Is that still true?
Thanks in advance
For all STM32 targets that I am aware of: Yes. This is a hardware limitation and not a software one, there is one interrupt register, where a bit is high if an interrupt happened. But this is shared between all the ports, so there is no way to distinguish between PC_5 and PA_5 having an interrupt, in both cases bit 5 of that register is high.
I suppose infinite checking of inputs is the only solution, isn't it?
posted by Son Hai Nguyen 11 Apr 2016
Probably yes, of course next to not re-using the same pin number for interrupts.
posted by Erik - 11 Apr 2016
