9 years, 11 months ago.
How to use MCP2515 for LPC1114FN28?
Hi everyone! I' m not good at English so this question is confusing. I am confronted with a difficult problem. Please help me.
My goal is construct system using CAN. And the system use only mbed LPC1114.
First, I try to use MCP2515 connected to LPC1768. Because mbed LPC1114 have not CAN pin like mbed LPC1768(ex: p29,p30) . It can work good. I use mcp2515.h library (https://developer.mbed.org/users/tecnosys/code/mcp2515/). This is very good library. It is useful function design.
Second, I try to MCP2515 connected to LPC1114. This is not work.
Error is bellow.
Error: Identifier "CANFormat" is undefined in "mcp2515/mcp2515.h", Line: 90, Col: 45
Error: Identifier "CANMessage" is undefined in "mcp2515/mcp2515.h", Line: 91, Col: 52
Error: Identifier "CANMessage" is undefined in "mcp2515/mcp2515.h", Line: 92, Col: 54
Error: Identifier "CANMessage" is undefined in "mcp2515/CAN3.h", Line: 22, Col: 19
Error: Identifier "CANMessage" is undefined in "mcp2515/CAN3.h", Line: 23, Col: 17
Error: Identifier "CANMessage" is undefined in "main.cpp", Line: 16, Col: 6
I think this error came from CANMessage class inCAN.h. LPC1114 is DIP so it has not FPGA like LPC1768.
I use two med platform. mbed LPC1768 (https://developer.mbed.org/platforms/mbed-LPC1768/),
mbed LPC1114 (https://developer.mbed.org/platforms/LPC1114FN28/),
and two IC. MCP2515, MCP2551.
and I change the library in can speed. because I use 20Mhz. I think to add the new header that define CANMessage. What I do this program.
My code is bellow
#include "CAN3.h"
SPI spi(dp2,dp1,dp6);// mosi, miso, sclk
CAN3 can(spi,dp10,dp11);
DigitalOut led2(LED2);
DigitalOut led1(LED1);
Serial pc(USBTX, USBRX);
char data[1] = {0};
can.frequency(125000);
CANMessage msg(2002,data,1);
msg.data[0] = 253;
can.write(&msg);
pc.printf("Send:%d\r\n",msg.data[0]);
led1 = !led1;
wait(0.5);
This is because the LPC1114FN28 doesn't support CAN in the device.h platform definition file. Therefore, CANFormat and CANMessage definitions are not included in the build.
Following header file example is a small hack to avoid this issue (i.e. to use CAN related helpers with Non-CAN platform).
can_suppor.h
#if (DEVICE_CAN) == 0
enum CANFormat {
CANStandard = 0,
CANExtended = 1,
CANAny = 2
typedef enum CANFormat CANFormat;
enum CANType {
CANData = 0,
CANRemote = 1
typedef enum CANType CANType;
struct CAN_Message {
unsigned int id; // 29 bit identifier
unsigned char data[8]; // Data field
unsigned char len; // Length of data field in bytes
CANFormat format; // 0 - STANDARD, 1- EXTENDED IDENTIFIER
CANType type; // 0 - DATA FRAME, 1 - REMOTE FRAME
typedef struct CAN_Message CAN_Message;
class CANMessage : public CAN_Message {
public:
/** Creates empty CAN message.
CANMessage() : CAN_Message() {
len = 8;
type = CANData;
format = CANStandard;
id = 0;
memset(data, 0, 8);
/** Creates CAN message with specific content.
CANMessage(int _id, const char *_data, char _len = 8, CANType _type = CANData, CANFormat _format = CANStandard) {
len = _len & 0xF;
type = _type;
format = _format;
id = _id;
memcpy(data, _data, _len);
/** Creates CAN remote message.
CANMessage(int _id, CANFormat _format = CANStandard) {
len = 0;
type = CANRemote;
format = _format;
id = _id;
memset(data, 0, 8);
#endif
And then, you can include this can_support.h from the mcp2515.h file.
I hope this helps. Toyo
