9 years, 11 months ago.
KL46Z ADC up to 5v
I am working with the FRDM KL46z and I would like to know if there is a way to work with the ADC conversor with Input Voltages up to 5 volts. I have seen on the reference manual, that there is a VrefH and also a VrefL but there are no real maximal or minimal values declared. In every application I have found, they take only inputs up to 3.3 volts.
Many thanks,
You may divide the input voltage; Tile 5K6 to and 10 K in series. Give 5V to 5K6's upper pin and connect the "joint point of 5K6 and 10K" to ADC input and connect 10K's other pin to GND.. t gives you appx. 3.3v for 5v input. But you should calibrate for precise result..
Thanks for your answer, but in fact I need to read a wider range than 0-3.3 v (from 0.7 volts to 4.8 aprox). I would take it in mind, but what I would like to know if it is possible to change the Vrefh value or not. (up to 5 volts).
posted by 07 Apr 2016
